majornelson
I have a MAC motor, 48V triangle pack battery and 9 fet 4110, 36-72V Infineon Controller from em3ev.com. Everything works great. I also have a 36V water bottle style battery (from Amped Bikes) that I'd like to use with the setup from time to time (much easier to take off the bike at work than the triangle frame pack). The Infineon controller is setup with a pre-charge circuit but the 36V water bottle battery has only positive and negative wires.
Am I risking anything by not using the pre-charge wire when I hook up the 36V battery? I'm assuming that this is built in to the 48V triangle pack's BMS and can't be added to the 36V battery...
Appreciate the help and feedback...
