pjgold
Yep just like having 20 year old legs again!
I couldn't have said it better. I rode 9 miles. W/O the mid drive I could go a 1/2 mile out and back. That meant my legs were done for the day. This is just what the Dr. ordered. Thanks all for the guidance!pjgold said:Yep just like having 20 year old legs again!
Somebodystopme!! said:This plug looks promising. I haven't found any data on the exact diameter of the plug but the pin outlooks to be the same.
http://www.ebay.com/itm/mini-xlr-6-pin-female-Audio-Microphone-connector-TA6F-/351058696978?pt=US_Computer_Microphones&hash=item51bcba9b12
6-pin mini xlr connector. The metal shield will most likely need to be removed in order to work. I'll find out when my plug arrives.
Also, cross your fingers, I have my Chinese contact checking on 25 connectors and 25 bafang original programming cables.
If he comes through with the actual cables I'll let everyone know and sell them at cost. Cross your fingers....
Like this?pjgold said:Had a little bit of luck today, I went to my local Jaycar store to get some jumper leads and found this plug that is almost the same as the green plug on the BBS02. It has a 7mm diameter but with a bit of careful filing it fits. So I now have a programming cable the works perfectly.
No problems with getting connection as detailed above and I was able to change the basic settings, however it looks like the pedal assist and throttle handle setting tabs are not working. I confirmed this by changing some settings and then reading the controller the settings on these 2 tabs do not change.
Arvicola Terrestris said:I think "Work mode" under Pedal Assist is Bafang's answar to a Torque sensor, it appears to be working with a combination of pedal rpm and pedal acceleration/deceleration.
I'm not sure if it is because I have the NuVinci autoshifter, but I can't get a good setting
How do you like the Nuvinci Autoshifter with the BBS02 otherwise? What kind of efficiency (wh/mile) are you getting at "X"/9 PAS setting?
erabbit said:Hi! Anybody have some magic PAS settings, i dont use handle throttle?
amigafan2003 said:erabbit said:Hi! Anybody have some magic PAS settings, i dont use handle throttle?
Try "current decay = 6" and "keep current = 100%".
tomjasz said:I have two BBS01's. One from EM3ev and one from Lectric Cycles. When It hit the throttle on the LC programed BBS01 there is a few second lag or stall before the motor kicks in. The EM3ev BBS01 has no lag or stall, or if there is it's much less apparent. I've written LeGrand but no response yet but it's only been 24 hours. The PAS on the LeGrand unit seems quicker to respond but I need to play and ride both bikes again to sort out any other differences. LC programs 5 levels and EM3ev programs in 9. Are there any settings in the C961 would make a difference?
I could with some guidance. I find the directions here somewhat confusing, but I'm learning. I'm just barely 5 weeks into my 2 BBS01's. I'd trade someone a gearsensor derailleur version for a finished cable.Somebodystopme!! said:tomjasz said:I have two BBS01's. One from EM3ev and one from Lectric Cycles. When It hit the throttle on the LC programed BBS01 there is a few second lag or stall before the motor kicks in. The EM3ev BBS01 has no lag or stall, or if there is it's much less apparent. I've written LeGrand but no response yet but it's only been 24 hours. The PAS on the LeGrand unit seems quicker to respond but I need to play and ride both bikes again to sort out any other differences. LC programs 5 levels and EM3ev programs in 9. Are there any settings in the C961 would make a difference?
It would be nice to get a screenshot of both units as they are set now. Then you could see what the difference was and fix it on the laggard. Do you have the ability to make your own cable?
skitime said:I need some help with the Bafang 750W settings. I figured those programming these things would know the answer to my question. My unit came with 5 pedal assist levels. I find level 2 too strong for much of what I do. I am assuming that if I increase the levels of PAS I will have smaller incriminates between levels. Could someone list the default power levels for 5 PAS and 9 PAS?
See my post above^^Somebodystopme!! said:FYI... If anyone lives in the southwestern US needs help with programming their unit PM me. I have a cobbled together cable that works great and programming takes just a few minutes. It actually takes longer to boot my laptop than it does to program the unit.
I travel all over the western US for business and can help if needed.
