tahustvedt
ErikDK said:Does the battery meter become useful if you raise the LVC?
Can you use make a 36V unit accept higher voltage by reprogramming?
My BBS01 250 W will not let me input higher cutoff volotages than 32 V.
I'm still learning and can't fathom why you'd want to?tahustvedt said:ErikDK said:Does the battery meter become useful if you raise the LVC?
tomjasz said:I'm still learning and can't fathom why you'd want to?tahustvedt said:ErikDK said:Does the battery meter become useful if you raise the LVC?
Thanks!
Tom
teslanv said:You will need to enter the COMM port ID in the software. Look for the Breakout Board hardware in the "Ports" Section of the Device Manager. Mine Was identified as "COM7"
Then, in the controllerst software, type in COM7 (or whatever port yours is) - The software should then be able to communicate with your PC.
Click "Connect" and you should be up and running.
tomjasz said:I keep hoping someone will manufacture a proper cable. I have my parts, just not a very clean setup.
maxwell92036 said:It seems like there are a lot of failures with the clutch mechanism in the internal nylon gear. I noticed there is a
PAS screen that allows you to change PAS settings. Is there a way to program the controller to take sudden loads off the nylon gear clutch mechanism so it lasts longer?
Or do people feel the size of the clutch mechanism is not up to the task??
maxwell92036 said:Well of the three motors I Purchased all developed the clicking noise so I am batting 1000!
Legrand fixed the one I got from him and I ordered the parts to fix the other two.
Great customer service from LeGrand from Lectric Cycles by the way!
teslanv said:maxwell92036 said:Well of the three motors I Purchased all developed the clicking noise so I am batting 1000!
What parts did LeGrand send for the repair? I fixed mine on my own without any parts - Just some thread-locker.
tahustvedt said:I managed to tune up the PAS now to the same level as the throttle. The "Keep Current(%)" setting was set to 20 in the stock configuration. I hadn't played with it before, but I set it to 100, and now I get full power while pedaling. I did lots of adjustments now and went out to test in a small hill each time I changed something, and this finally worked. Guess I can disconnect the throttle now.
pjgold said:tahustvedt said:I managed to tune up the PAS now to the same level as the throttle. The "Keep Current(%)" setting was set to 20 in the stock configuration. I hadn't played with it before, but I set it to 100, and now I get full power while pedaling. I did lots of adjustments now and went out to test in a small hill each time I changed something, and this finally worked. Guess I can disconnect the throttle now.
+1 for the Keep Current 100% this is the key setting is you ride mainly PAS, having the current back off at higher cadence makes no sense at all for a mid drive and you end up with this saw tooth pattern of power as it ramps up and down between each gear. I can see how It works well for a hub drive with fixed gearing though. To be honest I was a bit disappointed with the PAS of the BBS02 until kepler pointed me to this setting. I don't use my throttle at all now and have now set level zero as 1% current and 1% speed and have the throttle set to level 0, this means the throttle just kills the power which makes it perfect for gear changing.
The rest of the 1-9 levels are set to 100w steps.
