RICK
I've found pinch flats are largely dependent on my technique when installing tubes.If I check carefully all the way around both beads to be sure there are no pinches it helps a lot. No sliding of tire irons.
parajared said:
dingoEsride said:
Thats classic but I wouldn't want to corner with it!
auraslip said:I disagree with all of you. Here is the best method:
Thick Downhill or scooter tubes.
Stan's or slime tire sealant.
Any tire liner besides slime (they cut into the tube and cause flats. spend $5 more and get a better product)
Fat tires at lower PSIs.
Tires are cheap and wear down in a year. Good quality tubes and tire liners can last indefinitely. Tire liners can be a bitch to put on though.
Your recipe sounds great-- if the objective is to double the weight of your wheels, make them ride like crap, and turn any simple flat repair into a messy, time-consuming ordeal.
neptronix said:Start using puncture proof tires like the one i mentioned. You can go with a thick tube, but it's the tallness and strength of the thing that rests on top of the tube that does the majority of the deflecting of bad stuff.
I was literally going through a dozen tubes a month using all varieties of non-tire fixes.
parajared said:The "ghetto tubeless" method has held up for the month that I have tried it so far.
atcspaul said:that makes sense amberwolf. wasn't trying to be smart it just didn't make sense to me. guess i been living on an island to long
