auraslip
- Joined
- Mar 5, 2010
- Messages
- 3,535
I used this picture as the end all be all for my ebike designs when deciding where to put my batteries.
But I read something in a thread that piqued my interest they other day. Someone said that having the weight higher on the frame actually makes it more stable at speeds, while having the weight lower makes it more nimble at lower speeds. And this kinda blows my conception of bike handling out of the water because I always assumed that you wanted the weight as low as possible.
Low weight on a trials bike for better handling?
Anyways, my question is: does keeping the weight up higher really make a bike more stable at speeds, and if so, why?
As a follow up, besides positioning weight, what else can be done to make a bike more stable at speeds? My latest build is so twitchy that it weaves back and forward when I pedal it at 20mph. The frame reviews said the frame was twitchy (which seems dumb considering it's meant to be a loaded tourer). I have the batteries right on the bottom bracket going halfway up the bottomtube. I also have a fork that measures 120mm of travel when the frame calls for 80mm of travel or a max of 100mm. I assumed that the addition trail a taller fork provided would make it handle better at speeds, but I was wrong. I actually have the washer to drop the fork back down to 100mm, but I'm not totally sure that is the answer. Also, I could use a smaller front tire, but again I'm not sure less trail is the answer.
http://en.wikipedia.org/wiki/Bicycle_and_motorcycle_geometry#Trail
