wow, nice, thanks for the info Momo. 32 cells seemed easy to fit (space restriction-wise I mean, not work involved). I was still calculating to see if I could somehow shoehorn 40 in there but w/ a bms it has so far appeared to be highly unlikely.
how did you construct a frame to hold the A123 cells? do you have an internal bms?
and ya, I have all but written off the idea of using NiMh. like maybe if I could get 30 SAFT cells for free I would try it.
and and ya, the more I research it Lipo is looking like a very viable option now
but still, my 1st foray into Lipo probably shouldn't be locked in a hard to access enclosure. or maybe it absolutely should. or... maybe not.
so, I would be bulk charging the say 2X 5s 8000mah w/ a 36v lipo charger and I'd have the balance leads routed out so I could check individual cell voltage w/ a cell-log? and occasionally have to balance charge when necessary?.
waitwhat? I swore this would not turn into a "imanoob how do I use Lipo" thread. I mean I planned on finishing reading everything I could on the subject and starting that thread soon, but not for this project per se.
well anyways, the evolution of this project has gone from NiMH (Survey says NO) to A123 (Maybe) to Lipo (??). assuming I could securely/safely enclose 10s X AH lipo in a TF hub, what would you do to make it as close as possible to safe plug and play? Is it possible?'
DC
