SkilljoyJr
Every dual battery parallel module (example) I have seen either does not support regen or doesn't declare it doesn't, presumably because these are made with diodes which don't support charge in the opposite direction.
Otherwise I can only foresee using just an adapter which requires both batteries being at the same capacity, which is really bad, and probably impossible for me because I plan on one of the battery packs being used.
I've been eluded to that I could make my own circuit to allow regen for a dual battery parallel module, or maybe easier just have the regen just go into one battery. I don't know if this is actually possible and I have little experience with circuits but if it's possible I'd be willing to try and figure out how.
Is this idea possible or should I not pursue it?
