dirty_d
is there any defined set of rules or equations for the sequence the phases are to be commutated for a given pole/tooth count? for a stator with 3 teeth and 2 poles, i found the sequence i see everywhere to work, AB, AC, BC, BA, CA, CB, with the magnetic field rotating the same direction as the rotor. but for the same stator and a 4 pole rotor, the sequence was the opposite, CB, CA, BA, BC, AC, AB, with the magnetic field rotating the opposite direction as the rotor. i found 3 teeth and 6 poles to not work at all, and 3 teeth and 8 poles to maybe work but probably not good, i did all this stuff on paper with little cutouts i could rotate as the rotor with the magnetic potential vectors drawn on it.
so what are the rules? an odd number of pole pairs and the magnetic field rotates the same way as the rotor, and an even number of pole pairs and the magnetic field rotates the opposite way as the rotor?
and how about tooth/pole counts, is there some math to figure out what combinations work good and what ones don't work at all? that stuff is pretty confusing.
