4πr^2 said:
If truly the bolt generating the heat (and eyeballing those to be zinc plated steel bolts) - a brass bolt would have about half the resistance of steel, and a copper bolt would have about 1/6th, if memory serves.... maybe even less. So either of those two materials would create considerably less heating based on IR^2.
The bolt material's current conductivity is not relevant, because it only provides the clamping force between the actual conductors, which are the ring terminals on the wires and the top contact surface rings of the threaded tubes of the controller. The bolts don't conduct any current if everything is correctly installed. If the bolts have to conduct current then the wiring is not correctly installed.
Generally you'd want this order:
Bolt head
Lockwasher (to prevent loosening from thermal cycling, vibration)
Thick hard Flatwasher (to create even contact pressure all around the surface of the rings)
Ring Terminals of phase wires
Top Contact Surface Rings of the threaded tubes of the controller phase connections
Note that no or too thin/soft a flatwasher allows uneven contact of the phase terminal rings to the controller terminal rings, and creates higher resistance than it should. No washers at all means there is only pressure where the bolt head itself presses against the rings and potential loosening over time with thermal cycling and vibration. A lockwasher but no flatwasher means contact only where the lockwasher presses the rings together.
The faces of the ring terminals that contact each other and the top contact surface rings of the threaded tubes of controller are the conductive surfaces, and are what must contact as fully and tightly as possible. As long as they are very flat to each other and tightly pressed together, they will not generate heat from resistance between them.
Then the other source of resistance at that area is the crimp tube of the ring terminals where they connect to the wires themselves. If the crimp is insufficiently tight, there will be more resistance than there should be, and heat will be generated there.
If ring terminals and top contact surface rings of the threaded tubes of controller are in full contact, and the crimps are correctly done, then the other source of heat is the FETs in the controller itself, conducting thru the metal of the phase current paths out thru the threaded tubes of the controller connectors into the phase wires themselves. This is normal. If this heat is excessive, then it means the controller casing is unable to carry away the FET heat quickly enough (so the entire casing will also be hot), and a larger-surface-area heatsink needs to be attached to the controller casing, and/or greater airflow provided.
