dougcullen
Hi - I'm buying a battery spot welder from aliexpress
https://www.aliexpress.com/item/1-9kw-220V-Spot-Welder-709A-with-Soldering-Iron-Station-Spot-Welding-Machine-for-18650-16430/32614454614.html?spm=2114.13010608.0.0.FmEnsW
Im in the USA. The seller has said they can send me welder with a UK 220v plug. See attached image please of plug styles.
It seems that in the US there are multiple versions of a 220v outlet. What adapter will I need ?
Or should I keep it simple and use the 110v version ?
Thank you
Thank you
