mudflap5
Looking to build a battery. It will use 18650's and configured honeycomb style with several rows that are 2 batteries wide.
I have used 8mm strip on other packs, it seems like a wider strip would be faster.
Would like to use this to make assembly and welding a little easier. It is 0.15 x 27mm
http://www.aliexpress.com/item/High-quality-Pure-nichel-99-96-Battery-pure-nickel-strip-cell-connector-battery-pure-nickel-plate/32678144960.html?spm=2114.01010208.3.220.3hlrha&ws_ab_test=searchweb201556_8,searchweb201602_4_10017_301_407_406_10040,searchweb201603_8&btsid=1d6118ad-7d40-4e24-8ce1-82fd3e7c16bf
Looked at some pack builds did not see anyone using the 27mm wide strips.
Will this work?
Will this work?
