Hello guys, found this frame on Ebay and wondered if anyone has seen or know anything about it. The frame is made from steel and weighs 50lbs so its heavy by itself. https://www.ebay.com/itm/223999637065
Hey Jonno,
Thanks for your testimony. I just picked up that frame also. It has a 177mm dropout but I'm not interested in a fat tire. I want to find a 3000w 72v hub motor in a 26" wheel. Do you have a link for a recommended seller? Also looking for a matching front roller wheel. I've order the zoom forks to hold that wheel. Thanks for your recommendations.
I ended up ordering a hub motor from qs motors built with a longer axle. I will be going with a 18'' rim instead of the 26''. The tire I will be putting on will add a few inches to the circumference than the tire I was going to use.
