Did you watch the video .?... http://www.cleanenergy.org.au/renewable-energy-training/arvios-super-capacitor-energy-storage-system/jonescg said:Arvio questions.JPG
Just sayin...
Just sayin...
Start by reading the patent that was published yesterday. Just for clarification there is no in series dc to dc conversion and no electrochemical cells despite Richo’s determined effort. We fly these units on planes regularly at 40 x the allowable Wh limit of lithium ion electrochemical batteries. There is no riddle. No trick. Always open to a visit at our business from anyone who is curious about how it’s done, and yes you can see inside it. Over 100 systems are being installed over the coming months. Many of them will be on line for all to see.
wtf duz that even mean?... 40 x the allowable Wh limit of lithium ion electrochemical batteries.
Toorbough ULL-Zeveigh said:wtf duz that even mean?... 40 x the allowable Wh limit of lithium ion electrochemical batteries.
iz there sum legal limit context or iz dis auspeak?
guessing itz Wh per cc or gram or sump thing.
That will continue until one day a capacitor bank is shorted, and the resulting explosion blows a hole in the side of the plane.fechter said:There is a limit of how large a lithium ion battery can be to fly on a plane. Fire safety rule. Capacitors are not covered by this rule.
He is just refering to the 100Wh limit on lithium batteries allowed on aircraft.Toorbough ULL-Zeveigh said:wtf duz that even mean?... 40 x the allowable Wh limit of lithium ion electrochemical batteries.
That's not such a bad thing, though. If your motor controller has a working range of 42 to 29 volts for example (not unusual) you have gotten more than 50% of the energy out of the battery. And by changing the low voltage cutoff you can get >80%.Chalo said:It's bordering on disingenuous to compare supercaps to batteries for the same applications. The applications are very much not the same. Most battery powered devices depend on voltage remaining within a relatively narrow working range. Capacitors by nature don't and can't provide steady voltage. They slide linearly to zero as they're discharged.
Backtrack a few posts.Chalo said:It's bordering on disingenuous to compare supercaps to batteries for the same applications. The applications are very much not the same. Most battery powered devices depend on voltage remaining within a relatively narrow working range. Capacitors by nature don't and can't provide steady voltage. They slide linearly to zero as they're discharged.
Hillhater said:Backtrack a few posts.Chalo said:Capacitors by nature don't and can't provide steady voltage. They slide linearly to zero as they're discharged.
You will see that this "Sirius" supercap pack claims to operate between 44-54 volts .....(somehow ?)
Still sounds a little crazy - especially since lead acid has amazingly high instantaneous discharge capability. I could see it with something like the (now-defunct) Aquion battery, which has a very high ESR.spinningmagnets said:In this video, the Australian "Ultrabattery" combines lead-acid batteries with super-capacitors at the cell level. Fast forward to 4:24 to get past the intro and safety warnings (the remainder is 11 minutes)...Sooo...I guess all the speculation years ago of combining batteries with capacitors (for burst amps) was not as crazy as it sounded?
Re: DIY Super Capacitors, and Robert Murray-Smith
Post by Hillhater » Mon Mar 19, 2018 11:12 am
That RMS video of basic combining of supercapacitor and lead acid in one cell made me follow up on the "Ultrabattery". https://youtu.be/N1jusadHkmM
It may be old news to some of you , but the "ultrabattery" seems to have passed under the radar for some reason ?
On another thread (wind , Solar, coal, etc etc) i had posted about the Australian King Island micro grid project, with Solar, wind, diesel, battery storage, etc ,...all combined in a micro utility scale grid to research performance.
http://www.kingislandrenewableenergy.com.au
Dispite several enquiries i could not find what type of battery they were using, but now i have discovered they are using a 3.0MW, 1.6 MWh , "Ecoult Ultrabattery" ,..and have been for several years
However it seems impossible to get any detail feedback as to its performance etc
https://www.ecoult.com/technology/ultrabattery
So "Supercapacitor Batteries". Of one form at least, Are available commercially !
PS, i believe these "Ultrabatteries" are now produced in the USA by East Pen Manufacturing, under the name "Deka" battery.
http://www.eastpennmanufacturing.com/ta ... rabattery/
To steal a phrase from a famous Tech hero..... "Not a Capacitor as you know it Jim"Chalo said:Hillhater said:Backtrack a few posts.
Well then... that's not a capacitor. A capacitor stores charge across a dielectric, and the voltage directly reflects the amount of charge remaining. If that's not what it's doing, then it isn't a capacitor.
Hillhater said:To steal a phrase from a famous Tech hero..... "Not a Capacitor as you know it Jim"Chalo said:Hillhater said:Backtrack a few posts.
The agent (Arvio, and presumably the manufacturer, Kilowattlabs).. Are very insistant that this is a Capacitor storage device, with NO chemical battery content. They have offered an open invitation to anyone to visit , inspect, test, etc the device ....so they seem very confident
The claim is they have "secret sauce" electronics... (not dc/dc conversion).. Which results in the 44/54 volt range !
They have explained the Patent details as a "generalisation" which do not necessarily represent the actual device they are distributing.
