macribs
- Joined
- Jul 22, 2014
- Messages
- 3,702
StuInFH said:
Sorry I've reached that age that I can't seem to learn any more emjoi's. Don't know what that arrow means
StuInFH said:
StuInFH said:
sn0wchyld said:apologies if this has been answered, but cant find it trawling most the 170+ pages...
is there any confirmation on the bikes pin-outs? namely from the X controller? im specifically interested in the 3 pin triangle connector... can only find the 'other end' of the large white, little red stripe cable going to the main screen on the handlebars. the other two (purple and large white little black) - cant find where they go?
cheers
Merlin said:anyone upgrading the surron with nucular controller: get a domino throttle.
stock throttle works also but now i could compare both surrons with a nuc and the stock throttle is not that smooth as the nuc/domino package.
to be honest. worlds difference in smoothness.
No but that does sound way too hot... how tight is the chain? it should have just a little bit of play/slack. also make sure its well lubed. I've had chain running on a high rpm stage and it didn't get above ambient (12t to 60t running at ~4krpm at the 12t sprocket)Kauaiguy said:Primary chain drive kit:Anyone else running this kit?I put o ring chain for the primary drive kit and it runs kinda hot,about 135-140f ( can’t hold on to it) after about 5 mintues use.Is this amount of chain heat normal?
Kauaiguy said:I readjusted to a looser tension,just a little give in the chain now.Its a little cooler and less noisy .
AZeBikeGuy said:Kauaiguy said:I readjusted to a looser tension,just a little give in the chain now.Its a little cooler and less noisy .
A chain shouldn't be even close to tight - should have plenty of play
Rix said:These bikes can have the chain semi tight with very minimal slack and should be adjusted that way. Unlike motorcycles, there is no change in the secondary drive chain tension when the suspension is compressed or extended unlike motorcycles, because the pivot shares the same location as the secondary drive shaft sprocket. And because these bikes don't have a chain guide, you don't want alot of play or slack in the chain. If there is a lot of play in the chain, it could derail off the sprocket.
Merlin said:not really. 24s/100v is not the best idea.
for hot rod, all time running @ 60mph maybe. but if your avg speed is more 30mph you run all time less efficient as the 16s/18s package.
i think 18s would be the sweet spot and 20s acceptable.
but i didnt expect something brillant from a guy who ask the surron developer why he didnt use a bicycle chain....
Merlin said:average. not continue. with 100v and stock gearing the surron will hit 80+ mph.
if you design any EV, yes. go with very high voltage but also design the motor for it.
high voltage on the surron motor brings efficiency down (up)to ~60% (if you ride it normal) (justins motor calculator show that pretty easy)
if you ride it offroad with even lover average speed (and probably more power) you generate alot of/way more heat.
yea, your display shows you have a badass surron with 12-15kw of power. but thats for the luna surron facebook group guys.
most have basicly 0 knowledge that efficiency is the key in every way. power, heat, distance/range.
if you creep up a hill with a 100v surron at 10-15mph/5kw its probalby 2500w heat you generate in losses. dont wonder when your stock surron guy tops the hill with half the temperature.
btw: luna want to bring a package. not only a battery. so he will sell this as a package. probably asi. i dont know.
there are alot of speedheads. and all offroad buddies who will find out what luna sold will anyway deleted from public.
thats how he handle it any day of the week.
