One of the other posters here has asked the same question about the higher current units...but not the little 500W units...talking the big ones here...3kW or 1.5kW in a single supply and they are load balancing so you can stick two or three in parallel for real fast 5C charging
http://www.meanwell.com/search/spv-1500/spv-1500-spec.pdf
http://www.meanwell.com/search/rsp-3000/default.htm
think I did see something about not being able to use the Voltage trimmer though if load sharing is enabled..maybe they mean voltage trimmer is not available on all but one of the supplies...and one of them controls all the voltages...that would make sense.
No idea what these units cost though...Not planning on looking it up yet though...but the extra cost is probably easily offset by the fact you have one unit to wire up rather than two or three.
Here is my unit finally finished
I got my two S-350-48s wired up.
Mods done are:
Fan mod Q5 resisor C-E bridge with switch
CC/Cv board switchable in/out for series or parallel ops
SVR1 replaced on both supplies
SVR2 added on both supplies
These were mounted externally ...see the front panel picture...the letter box like slot.
Actually used two pots for SVR1 on each supply and two pots for SVR2 on each supply
All pots were 16 turn cermet 5k trimmers
They are connected up to the boards via a 4 pole change over switch...so I have two voltage limits and two current limits...higher volt limit...lower current limit
The second 4 pole switch changes between series and parallel. It also switches the negative feed so, in parallel the negative feed is direct from the PSU, and in series it is through the Goodrum Fechter CC/CV board
Small switch in lower middle, is double pole and switches the CC/CV board voltage feed and voltage sense line in and out. That was an after thought fit ...as the CC/CV board was pulling the voltage of one board down when the units were in parallel
CC/CV board VR 1 2 3 just below letter box
HVC connection and Float enable jumper also bought out to front panel
Small jumper loop wires at the bottom are monitoring points. I can put in ammeter in series their to monitor current from each supply when they are running in parallel...Seeing he current I can adjust the external voltage trimmers to get even load sharing.
Swiches along the top of the board...two over ride switches for the meanwell fans ( Switch across collector -Emitter of Q5...a better mod than the thermistor mod as ..according to Commanda.
Middle switch directly drives the middle fan
Commanda said:
Good point of doing it this way, the thermistor "stage 2" protection still works as designed. If it does overheat (because the fan failed), it drives the Dead Time Control on the TL494 to cut the current by reducing the pwm.
The people that mess with the thermistor lose this.
