oatnet
Thanks for the excellent guide Luke, I got one of the 8x8s from Methy so I'll give it a try.
-JD
-JD
Spacey said:Even though I've bought a 40amp Sensorless controller for my 9C, I was going to attempt to get the Halls wired up but gave up after it was going to be an impossible job to dig them out of the stator.
I do like the 9C motor a lot and really hope that mine works after all the work I've put into it, just waiting on the sensorless controller to arrive.
torker said:Spacey said:Even though I've bought a 40amp Sensorless controller for my 9C, I was going to attempt to get the Halls wired up but gave up after it was going to be an impossible job to dig them out of the stator.
I suppose if they were still glued in really well they may be a little tight. If you look closely you will see they are actually in slots. Centrifugal force cannot dislodge them because they will only slide out to the side. Right at the bottom of the slot was a tiny bit of clearance. One that was still bonded well would probably have glue in that spot. I sharpened my tool much like a small flathead screwdriver and was able to push it in under the hall and twist a little and slide it right out. Maybe someone will have a clearer pic than mine.
Spacey said:Yeah I should have tried hard to get the sensor wires going as well as the 12awg upgrade as I have lost a lot of top speed going sensorless, used to be 37mph is now 25mph on flat Only just got the speedo working again.
auraslip said:Once again thanks for doing this for us luke:
Two questions for you guys:
1: What size shrink fits 12 awg nice and tight?
2: I want to run smaller wiring for the halls and temp sensors. Hobby king only has 26 awg and 36awg - Will 36 awg work for a run from the controller to the hall sensors? Should I heat shrink all three wires together for security?
Thanks ~
4: 10awg wire insulation is thick. Even the best teflon wire insulation is thicker than you can fit for 10awg. Shrink wrap is thin. You will need 3mm shrink wrap if you're going to fit 10awg. 10awg wire can BARELY tuck into 3mm shrink, you need to first straighten the strands out.
auraslip said:4: 10awg wire insulation is thick. Even the best teflon wire insulation is thicker than you can fit for 10awg. Shrink wrap is thin. You will need 3mm shrink wrap if you're going to fit 10awg. 10awg wire can BARELY tuck into 3mm shrink, you need to first straighten the strands out.
? So I'm guessing 4mm shrink?
I'm more worried about using 36 awg wire for the hall sensors.
auraslip said:I'm not even gonna try 10 awg cause I'm not doing mad current and I'm lazy. I'll try 12 awg with 4mm and see if the stock halls and stock temp sensor wire fits.
amberwolf said:Oh, come on, every company has a really good QC program...it just stands for Quick Check now.
liveforphysics said:
