I dunno if it's a world record or not (I suspect it isn't), but it was a record for this trailer at least.
Yesterday in the parking lot at work, I had an encounter with another aggressive, stupid driver in a small white SUV. Something about those things seems to make people want to hurt others, and de-brains them.
The parking lot isn't well-designed, but it looks like this (north pointing up):
where I'm the yellow triangle pointing east, and the SUV the green box pointing north.
That's a 3-way stop, with signs at the red hexagons, and clearly marked large broad lines where you should stop (though they're not that clear in the pic, they are when you're there).
I came to a complete stop, as usual, at the western sign/line, with another car (handily already in the image) right behind me.
The SUV was approaching their line/sign, and began to slow a bit, just as I was beginning to startup from my stop.
Then, without ever coming to anything even resembling a stop, they accelerated right in front of me and went around me as I was already in the intersection, while opening the driver side window and yelling out the window "YOU SHOULD STOP TOO!!!!" as they passed my left front quarter, and continuing to accelerate around and past me.
This makes no sense. Even if I had not stopped (which I did), I was already completely in the intersection at that point, about to be in front of them. They did not ever stop at all, and so could not legally or safely continue into the intersection, whether I was there or not. If I'd been accelerating a little faster, they would have just run right into my front right quarter, and crushed the front of the trike, possible me, too.
Most likely they were not paying any attention and didn't even notice it was a stop, much less that anyone else was already previously stopped at the cross-way to them, and was then proceeding thru the clear intersection as normal, safe, and legal.
Well, safe except for when there's people like them near it.
Unfortunately that kind of maneuver (minus the shouting) happens fairly often there--thankfully it's not usually to me. Infrequently there are collisions resulting from it, or pedestrians/etc that are hit.
Aggressive idiots.
EDIT:
I was looking at the streetview of the place, and as it happens, it caught the same basic thing happening on camera. The difference here is that the car coming from the south (on the right in the pic) would represent me (already in the intersection) while the other one is just starting out from it (in front of the camera car). I don't know in this pic which of these cars actually is in the wrong, of course, but the situation looks very similar to mine, and happens there all the time. (it's a lot worse since teh In-n-out burger place went in several years ago, before that it was a problem, but not anything like as bad as it is now).
That said, continued data from the new motors shows a continuation of hte lower wh/mile, it's been about 48wh/mile average for my commutes this week, pretty much no wind.
Another couple of data points:
--when the pack is fully charged, there is almost zero braking via the ebrakes, until it gets down to IIRC about 10MPH, at which point the EABS (right motor) pulls harder and I get a significant but insufficient boost to the braking. The left motor (regen) also pulls harder at that point but not as much as the EABS does.
--when the pack is about half empty to 5/8 full, there's a great deal more regen braking (left motor) than above that point, dramatically so to the point that when speed drops to the boost point, it actually squeaks the left wheel just an instant as it loses traction, under some conditions. This stops immediately after that; it's just the sudden boosted regen braking that does this, at that transition from the above-boost-point to post-boost-point behavior.
If I could get braking that good all the time, I'd be happy with it. Well, if I could get *proportional* braking, with analog control of the force, but with wheel-squeaking power at peak, anyway.
Aggressive idiots.
EDIT:
