So apparently I did a number on my controller when it blew. Lyen has put a bandaid on and I should get it back shortly.
I may get my wheel trued this week. They trued it once. The wheel has settled after 200 miles. Has a little wobble. Take it back in for a little touch up tender loving care. After that I maybe able to tighten the gap on the brakes to make them work more effectively
Ebikes are expensive. I just made several purchases today.
One was the Multi button from Hyena. I mainly wanted a button for regenerative braking. But he has a nice cluster thas all in one. S15.50.
I also bought this keychain camera. Supposedly shoots pretty good video. I plan to put a small 1inch square of velcro on the frame on the flat area of the headtube.
http://cgi.ebay.com/Version-3-Keychain-Spy-Camera-4GB-Memory-Card-1Hr-/230511942942?pt=LH_DefaultDomain_0
I bought a West Mountain Radio TriCrimper Today
I also watched alot of videos and read alot of forums to help me make better connectors. One tip is to tin the wire, crimp on the connector, and heat the connector back up until the solder flows and you have a good solid very conductive low resistance connector. Make sure the connector is straight. Ive had a habit of bending them slightly downward. Dont force it. It makes the hump flat and causes poor connection.
25 sets of 30A Connectors/Housings
25 45A connectors
I also bought a fuse from them Its a 40A inline fuse. One is on the positive and negative lines. It has 10G wire and Andersons On each end. That was to the tune of about 80+ bucks.
Ive spent about 200$ On my bike. Im going to have to put those Turnigy Lipo Packs off for another week or month. I got a wedding coming up in less than a month.
