I'm somehow convinced that fusing individual cells is a good safety feature but I lack electrical skills to answer this question myself.
I'm trying to build a 20s3p high current battery with Molicel P42a cells. The controller is able to pull 50A continuously and 65A peak. So each cell will output a maximum of 16.67A (21,67A peak). Which with respect to the cells datasheet should not be too much of a burden for them. Note: I'm not saying I'll be pushing this much current all day everyday because I expect things to start failing like bike transmission but I would like to design the battery with these constraints in mind.
So my question is: what fuses should I use? Most people are using wire fuses. I found fuse wire good for 30A but it is designed for home applications (230V). Next I saw car fuses. Will those work properly?
