Dui ni shuo de dui
Hello everyone,
Usually, when we talk about batteries, controllers and so on, the two ratings "peak current" and "continuous current" rapidly appear. I understand the general principle of what is a peak and what is continuous, but is there an actual standard who scientifically defines what is a peak?
It is obvious to me that one of the most important point would be the time component. So how long is supposed to be a peak exactly? 1 second? 2 minutes? half a nanosecond? Where is the limit between peak and continuous?
It really matters a lot because 30KW for half a second is definitely not the same as 30KW for 5 seconds.
Some manufacturers will sometimes tell you how long those peaks migh be, this essentially applies in datasheets for controllers, I've more rarely seen it on batteries. For instance, one manufacturer will tell you that this controller can handle a peak of current of XXX Amps for 10 seconds, this other controller can handle a peak of YYY Amps for 1 minute, etc. So it seems to me that there is no consistency in what a peak might be.
An other thing I'm wondering is what voltage sag is associated to these current peaks? You can have a peak of 3000 Amps, but if your voltage then sags to 0.1V it is just pointless.
So my question would be, is the "peak current" figure just some kind of marketing stuff manufacturers communicate to unaware customers, or is there an actual, real life standard who defines it clearly. And if yes, what is it? How long should a standard peak be? What % of voltage sag is allowed?
Thanks in advance for anyone having an answer to that
