hello,
seeing all these epic build with 7 kw rc motors got me thinking, is there any kit that has as good or better performance then 7kw rc setups?
thanks,
Jacob R
hello,
thanks,
Jacob R
Well they are 'off the shelf' units not one offs, Matt sells everything needed to bolt these up i.e reduction drives, slipper clutches, mounting hardware, motors, throttle interface, Magura throttles, Castle Creations ESC, disk brake sprocket adapter, sprockets...all you need is the coin and some basic tools to fit it
thanks for the info. one more question is the astrofligth 3220 worth the extar cash over the turnigy 180kv? and why stop at dual motors why not triple (jokes)
thanks,
jacob R
Quality wise it is no doubt, whether you can afford it is the question if you can 3220 all the way. The comparable size Trunigys can be improved upon with a lil extra expense and time, they are a slightly more powerful motors also.
ev_nred said:
and why stop at dual motors why not triple (jokes) thanks
One is more than enough on a MTB with their short wheel base. Lota fun when in trikes though :lol: Matt has since gone back to one motor to make the trike a lil tamer and still i think its good for around 45-50mph IIRC.
