dogman said:
Wouldn't a 6 phase 10 halls controller technically be 2 controllers? I don't mean just a y connector in the wires, but two separate timings.
I think Thud did run two brushless motors on one controller, by a chain and sprocket linkage of the two motors keeping them in synch. If I understand it right, losing synch fried one of the motors later in the day.
Well the initial power conditioning circuitry that feeds the output channels (voltage regulation, smoothing etc.) could be the same, you could also use the same microcontroller so long as it has enough i/o pins and ADC's onboard for the double the inputs and outputs. There would just be 6 phase output channels on the controller and using software you would drive the correct outputs in conjunction with the sensor inputs (or read the right phase lead) to drive the two motors.
The advantage of this is you do get to cut off some of the redundancy you would normally have with two completely separate circuits (reducing size), and the two motors would be driven by the same microcontroller so you could more easily do different control functionality like power balancing, and speed matching between the motors. Without having to make two microcontrollers talk with each other.
I bet Thud's motor burned because chains still have a bit of stretch to them, and the more poles the motor has the smaller the rotation needed to fall out of phase. Give it a bit of gas the motors fall out of phase, something probably shorts in the controller and you get the magic smoke everywhere. The only real feasible way you can run two motors on one controller is if they are both on the same drive-shaft. Only that will have low enough play to not be a risk, you still have to be careful in the initial alignment of the two motors keeping both phases as close as possible, as any misalignment will make you lose power.
spinningmagnets said:
Maybe I was wrong to state it that way. Most hub-motors I've read about use hall-sensors (and a few use optical sensors) to let the controller know the exact position of the rotor in relation to the stator. A sensorless controller uses the back-EMP to try to figure out where the rotor position is at any given time, so...
I believe Crystalyte makes a dual-motor controller, but it's my understanding that it's just two separate controllers in one box. I believe the original poster (OP) was talking about using a single controller that was intended to operate one motor, and using it to run two motors (splitting off the 3 phase wires into 6).
I think you started to talk about brushed controllers and switched mid-sentence to talk about brushless controllers so I was a bit confused.
The Back-
EMF (EMP is what nuclear bombs make) is used in sensorless motors since only two phases are energized at any time, so the third phase is read by the controller. The motor acts a bit like a generator for the third phase and makes a voltage pulse in the unpowered phase. With a bit of extra maths this gives you the position of the motor.
Only problem with sensorless is since it requires the motor to be turning to figure out the position, they tend to start out rather rough, and if you rotate the motor backwards, cheaper controllers tend to go up in smoke.
Edit:
In short to the (OP) you cant use one controller designed to drive just one motor and parallel the phase wires coming out. Why? Because Fire.
