Milou
1 W
Hi: I have a Chinese motorcycle scooter with a 48V DC to 12V DC Converter. There are three wires coming IN and OUT (Yellow, Black, Red). I traced each. Given their resources and output I am assuming as follows:
RED (Ignition, Instrument Panel, Controller) is the 48V input?
BLACK (Headlights, Horn, Instrument Panel, Controller, Kickstand [has safety switch], Battery) is the ground?
YELLOW (Headlights switch, 12V relay, Horn R switch, Horn L switch, Brake lever switch, Instrument Panel, Rear connector, Kickstand Switch) is the 12V output?
Would it be safe/easier to have the ground directly onto the frame with appropriate reference electrical source (battery) ground to the frame?
I would like to replace the DC to DC converter with a 12V xxxA battery of my own setup. I notice this not being the norm. Is there a logic/reason/safety issue with the separate setup (besides charging/maintaining another battery)? My desire is to play around with the motor controller modifications without worrying about the other electrical issue accessories.
Thanks in advance for replies. Regards JJ
