Gingerbug said:I can totally wait a month or so. I will use paypal then too. when u get them in could you hold one for me? If so I will try to reask in about 30-40 days.
psychotiller said:Rode a few miles tonight on the WiiPintail and noticed now that when I use C, unless I set my speed by holding the toggle right for a few seconds, C will gradually keep increasing my speed even if I toggle down it would still speed back up. As far as issues go though, it wasnt that big of a deal.
torqueboards said:psychotiller said:Rode a few miles tonight on the WiiPintail and noticed now that when I use C, unless I set my speed by holding the toggle right for a few seconds, C will gradually keep increasing my speed even if I toggle down it would still speed back up. As far as issues go though, it wasnt that big of a deal.
What you've described is how it currently works. You would set your start up cruise control speed to a lower speed to avoid that issue. Let us know if it's much of an issue.
Are you using the latest updates? You should set your cruise control start speed first with your board flipped over (usually anything fast is actually slow) bring it up to the cruise control start up speed you want with the (cruise control and toggle up/down to control speed) move to right or left for about 5+ seconds and it should slow down and start back up once it accepts the new cruise control speed. This setting shouldn't change and should be set until you try and reset it again.
The way you describe it is actually how cruise control works. If you plan on toggling down completely below your set cruise control speed -- I would probably set my initial cruise control start up speed to a much lower speed then the current.
psychotiller said:Setting my cruise speed only works until I toggle up. If I hit c again after toggling up it is increasing speed all the way up to 37mph. even if I toggle down to slow down, if I keep my finger on C it will cruise right back up to max speed again.
psychotiller said:Yeah, I need to practice the whole arduino thing anyway. I'm not that worried about it honestly. I love this thing so much better than the RC controllers.
C:\Users\Tony\Documents\Arduino\libraries\Nunchuck\Nunchuck.cpp:125: error: no 'boolean Nunchuck::cButtonPressed()' member function declared in class 'Nunchuck'
C:\Users\Tony\Documents\Arduino\libraries\Nunchuck\Nunchuck.cpp:137: error: no 'boolean Nunchuck::zButtonPressed()' member function declared in class 'Nunchuck'
torqueboards said:psychotiller said:Setting my cruise speed only works until I toggle up. If I hit c again after toggling up it is increasing speed all the way up to 37mph. even if I toggle down to slow down, if I keep my finger on C it will cruise right back up to max speed again.
We'll have to double check with Austin... Last time I got it working I basically had to trick it to run cruise control at a lower speed and then set the lower speed as cruise control. You can also try re-flashing it and the resetting the default cruise control.
gcebiker said:Tried, versions 0017 , 0020 , 0022 and 1.0.5 ...still getting
when i try to compile code from - http://bjorn.us/tech/wireless-nunchuck-controlling-pan-tilt-servos/#comment-110
DodgyBob said:Will other brands wireless nunchuks work also? I lose connection with the nyko alot and its getting frustrating. Its not easy for me to get a memorex. They are sold out everywhere.
austindavid said:We'll have to double check with Austin... Last time I got it working I basically had to trick it to run cruise control at a lower speed and then set the lower speed as cruise control. You can also try re-flashing it and the resetting the default cruise control.
psychotiller said:I know how to set and reset the cruise control speed now. The reason I brought this up is because even after I set it to super slow, use my cruise for push off speed, let go of C, toggle up to speed, hit c and cruise at speed for awhile, let off C to slow down, Hit C for my "set" kick off speed but get a slow gradual acceleration all the way to top speed. (even though I never set my cruise to top speed) I'm definitely not accidentally resetting it.
torqueboards said:psychotiller said:I know how to set and reset the cruise control speed now. The reason I brought this up is because even after I set it to super slow, use my cruise for push off speed, let go of C, toggle up to speed, hit c and cruise at speed for awhile, let off C to slow down, Hit C for my "set" kick off speed but get a slow gradual acceleration all the way to top speed. (even though I never set my cruise to top speed) I'm definitely not accidentally resetting it.
If it's within 5 seconds of your last cruise control and you hit C again -- it will go to your last set cruise control speed. If you wait till after the 5 seconds, it should revert back to your original set cruise control speed.
We have a 5 second auto pick up on the last set cruise control speed - in case you want to slow down for a few seconds and pick up again at your last cruise control speed.
Not sure if that helps but let me know if I'm not understanding you properly. Would this be a feature -- that you would like or no?
