p42a and mnke liked longer wait times than the 40T, instead of 5minutes and 2minutes they like 30min and 5min so im trying these settings to compare mah loss per cycle
battery has been sitting on the shelf for 30 days, voltage dropped by 0.07 volts, its last discharge was 3016mah. charged to 4.2v to start test
cycle #422 battery discharge starting voltage was 4.2v, #423 was 4.191v
#422 d-3040mah, c-2965mah
#423 d-3016mah, c-2975mah
#424 d-3021mah, c-2979mah
#425 d-3022mah, c-2981mah
#426 d-3024mah, c-2982mah
#427 d-3024mah, c-2982mah
#428 d-3023mah, c-2982mah
#429 d-3024mah, c-2983mah
#430 d-3021mah, c-2979mah- the box the battery is in was open and peak temp dropped. closed lid again
#431 d-3020mah, c-2979mah
#432 d-3021mah, c-2980mah
#433 d-3021mah, c-2980mah- aug7, 7pm done for now.
