Hi there,
I'm building a 14s2p battery.
I was wondering if there's any reason I couldn't weld the nickel strips in an X pattern, like shown in blue, rather than a typical rectangle as shown in green?
The reason is, it would reduce the number of strips I need to weld (2 strips per quad, rather than 4), and also avoid having to layer up, since welding a second layer on top of a previous layer is both difficult and unreliable.
I can't think of any reason why not, but I'm no electrical engineer. In either pattern, all four cells are connected together via a single continuous connection, so parallel balancing should still happen. In the X pattern, the series path (high current) still has two full nickel strips, so no reduction in capacity.
If I go the "X" route, I'd probably add a few welds at the intersection of the two strips, just for good measure.
Thoughts?
Thoughts?
