adamsavage79
So I've been having problems with my BMS low voltage protection kicking in too soon, and I the pack on the charger. The charger did it's thing and all 16 leds where on. Then the strange thing started to happen. They kept flashing on and off, and doing the night righter things, where, they would light up in sequence. The voltage coming from the Charging port was 56.6 volts, give or take 1/10th of a volt, but the voltage from the discharging cable was not the same, and the BMS would not allow power to go to the kit.
The voltage very slowly climbed upwards, until it matched the same Voltage on the Charging port. Once they matched, the lights on the BMS turned off and stayed off. From there, the pack voltage slowly stablized.
I've never had any pack do this before, and I don't know why it did this, or if it has done it before. I know I've done partial charges and I've been able to use the bike right away.
