piwhy
Hello,
I recently bought a 20" hub motor wheel to convert an old moped into an electric one. I bought the Sanny 48V1000W model on Ebay with a basic controler and some misc accesories.
I started to realise some tests with the basic 48v controler and 4 lead batteries and I'm not satisfied with the maximum rpm...
I will order LifePO4 Headway cells (40160S) soon, with a Kelly Controler with regen function and I'm wondering on the system voltage.
I'm wonder if I could use this motor on 60v (20 cells) to gain some KPH ?
As the Kelly Controler is configurable, I can limit the maximum current in the motor.
Does someone ever used this motor with an upper voltage with a kelly controler ?
Thank you.
Bye
Thank you.
Bye
