Link
So, I was working on setting up my bike, and suddenly it doesn't work. Here's what happened:
I get everything all nice and running and test it. Works fine. I zip-tie the cords to the bike and saddle up with the backpack. I turn the throttle a little. A fraction of a second acceleration and then nothing. Needless to say, I was both pissed and confused. Everything had worked a few minutes earlier. It got even more confusing when I started testing things.
At first, I thought it was the throttle. I had similar problems with the first. The hall sensors signal and negative legs kept touching and stopping the motor. I opened it up and used a little hot glue to hold them in place. Got me nada.
I knew it couldn't be the breaker or Doc Wattson, because the Doc Wattson was giving its readings normally, and it's behind the breaker.
Worried now, I figured it might be the controller, or worse, my very labor-intensive wiring job. Unplugged the motor and attached a voltmeter to it's leads. Turning the throttle varied the voltage just like it should.
Now I'm starting to thing I did something terrible to the motor, somehow. I hooked up the voltmeter to it and spun it a little. Luckily, I got voltage out of it, so that wasn't the problem.
By now I'm almost completely at a loss, but I decide to go back to checking the wiring. Throttle signal is getting through. Voltage is present, so the wires have connectivity. Motor works fine.
I go through about every test I can think of, and eventually I figure out the problem. Guess what it is. I find it kind of interesting, actually, even though I have no idea how it managed to do this.
