Föppel
Hey Folks, i can need some help with my Bafang BBSHD problem(s).
After i replaced the Nylon Gear in the motor (peanutbutter), i put the Motor back together, and had a Hallsensor Error-code (08).
Motor did move the Chainwheel 1cm, than stopped, display showed Error code 08, peeping noise came from the controller while pulling the throttle.
after this, i opened the Motor again, hallsensors looked nice, also the the soldering on the
Hallsensor-Board (both, from the Sensors and the white JST-Connector) looked not that bad, but i resoldered them, to get sure. put everything back together, and the Sensor-Error 08 does not show again since this procedure. But the motor does not move, and still making this trange peep-Noise from the controller when pulling the throttle.
i also tryed to unplug just the black JST-Connector from the controller (it was a tip i found, if you have the 08 Error...)
...oh, and i checked every connection multiple times... not sure what to try next. Anyone a good idea?
