I'm trying to connect a throttle to a servo tester. I looked online and I found how to do that. After I did everything, its still not working... (the motor beeps continuously after I connect it to a battery)...
Did I mess up the circuit?
I just removed the potentiometer and I added a wire between the "-" (IN) and "+" (OUT).
After that. I connected the ESC to the OUT side and the throttle to the IN part.
I also tried connecting the "-"(IN) to the middle dot where the potentiometer was. If i do that, the motor will beep twice after I connect the battery (as in thats the max), but it wont receive the min. Maybe the throttle potentiometer is too small? (the range is too small)
