I normally don't post here in this section, but...I thought this might be useful for some of the hackers here. $200 for the full kit, $100 for a second battery, $50 for a second charger... $400 for 2WD?
Each chainsaw has a brushless RC outrunner, 63-54mm, 300Kv, with a shaft-mounted centrifugal fan. 12mm diameter shaft (easy to turn down to desired dia), also, motor uses 3 hall sensors (included)
http://www.etotheipiplusone.net/?p=3324
