Well, it’s not really a scooter and definitely not a skateboard but hopefully it will still have a place in this world!
This is my mechanical engineering design project partially inspired by boards like the dirt surfer.
Specs
• Battery: 10S 3P soldered from Samsung INR18560 25R cells (~260 Wh)
• ESC: the incredible VESC setup in BLDC mode
• Motor: Xnova 4025 560 kv 24 slot 8 pole
• Drivetrain: 2 stage gates GT3 15 mm width belts with roughly a 16:1 overall reduction (17:60, 26:120)
• Wheels: MBS Rockstar Pro for easy pulley mounting, 200 mm diameter tires
• Deck: 2x 6mm thick carbon fiber plates roughly 150mm by 600mm
• Frame parts: 0.5 inch thick 7075 aluminum
• Steering: 4 bar linkage based positive caster system (15 degrees of rotation in each direction)
• Mass: 6.7 kg or 14.8 lbs
• Top speed: calculated at 38 km/h or 24 mi/h
• Max gradient: calculated at 27% with my 70 kg mass
• Turning radius: not great, maybe 3.5 m
• Range: really depends on a lot of variables (read as haven’t tested yet)
Completely fabricated by myself with just a Shapeoko 2 CNC router and a drill press. Anyone can do it!
Still trying to find places to test ride it besides my apartment hallway due to the snowy northeast Ohio weather!
Renderings
Specs
Renderings
