Voltron
So in the middle of figuring where everything is going to go with this BHT install, and stumbled across a hub with bolt on axle, disc brake mount, and special short freehub, 3 bucks at the bike co-op.. It lets you stack a few gears, but the hub flange is wider and less asymmetrical than a normal cassette hub.
Setting up the mid drive is way more involved than a hub motor, but really liking the idea if being able to swap wheels and tires for different rides.
These are both 20", one with a giant for 3" Kenda, the other with a smallish 2.4"
That 2.4 is a Schwalbe Energizer.... it's a solar race car tire! It's 116 psi, 60 mph rated, and made for low rolling resistance, perfect for distance runs. Then will be able to swap in an off-road or cheap burn out tire.
Getting kinda excited as the parts are coming together!
