As far as I know BionX software wants to update 30 days after installation. This is not possible any more because Bionx servers are down.
Therefor the BionX needs a faked date, based on the installation time hidden in the license file bbi.db.
I can only use it when I set back that date manually and use my PC offline.
I use a bit older license version, so I may date varies from the date you need to use for that version, at least this is what I believed. I assume that you have to set the date for this version to somewhere around November 2018.
Your PC still uses the actual date and the software works?
If so, I don't know why
