gtoal
- Joined
- Mar 2, 2014
- Messages
- 13
I ride an E-Moto Ridge 2.0 which is now 2 years old and I have two extra manufacturer's battery packs to take with me for extra range which I swap out when each pack is exhausted. The vendor replaced one of them that lost about 33% capacity within the warranty period, but that's now expired and the other two batteries are starting to lose capacity too, so I decided that the next replacement would be a 20Ah lifepo4 pack that I could mount in my rack and not hassle with changing during a ride.
I ordered one from China where it was built to order. I asked for something suitable for a 250W brushless hub motor. They were never very forthcoming with details but this is what I bought:
Item: 12S1P-- 36V20ah lifepo4 battery pack
Unit price: US$203/pack.
The cost of 12S 4A plastic charger: US$42
BMS Specification:
12S working current: 7A Peak current: 14A
The cost of BMS: US$26/pcs
The shipping fee: US$160
Total value: US$431.
I wired up suitable plugs so that I could power the E-Moto from it, and disconnect from the bike to charge it, then I tested it...
If I start pedaling from a stop, the battery cuts out immediately, and won't re-engage until I physically unplug and reinsert it. Just using the on/off button on the handlebar doesn't reinitialize power to the bike, which suggests to me that the battery pack has shut down rather than the bike.
However if I use the throttle alone to pull away from a stop (not a good practice) and then start pedaling once the engine engages, it works fine and runs indefinitely (well, at least until the next stop at a junction)
(Here's a potentially related issue: if I feed the battery through a 37V to 12V converter into a 12 - 110Vac inverter, the inverter powers itself off immediately I try to power it up. Even with no load attached. I've done the same thing with the EMoto vendor's battery packs and they power the inverter just fine.)
So I can work around the problem at a pinch but really am not happy with that solution. Does anyone have any ideas what's going on here? Some parameter set wrongly on the BMS that's presumably inside the battery pack? Is it fixable? Shipping the battery back to China is not an option. I don't know if removing the tape to examine the BMS is an option - they told me it was compression tape and not to remove it.
Thanks,
Graham
PS I have some stories to tell about dealing with the Chinese company but not relevant at this point, and I'll withhold their name until I'm sure of the facts here.
BMS Specification:
Thanks,
Graham
