silviasol said:I want to use them to see inside walls. I need to know if there are studs behind a wall or concrete when I am looking for a condo. I just made another thread about that. I figure if someone has one they could check that out before I spend the ~$250 on one.
Punx0r said:silviasol said:I want to use them to see inside walls. I need to know if there are studs behind a wall or concrete when I am looking for a condo. I just made another thread about that. I figure if someone has one they could check that out before I spend the ~$250 on one.
Just tap on the wall with your knuckle?
Drunkskunk said:I bought a Seek Thermal camera, as it said it was compatible with my phone. It doesn't work, because my version of the phone doesn't have functional OTG USB. it took me a month to figure out the problem. My model phone is OTG compatible, but this phone's hardware revision didn't include it.
Yes but aren't there still studs connected to the concrete? I would imagine something would be there to hold anything you would need to bold to the walls.
nutspecial said:Yes but aren't there still studs connected to the concrete? I would imagine something would be there to hold anything you would need to bold to the walls.
Unless you can observe the varying density of wall material quickly changing temperature from ambient, I'm not sure how one of these things would work to identify what's behind drywall/plaster. Maybe on a wall getting hard sunlight in an air conditioned house, or if you have that rail gun Arnold likes from 'Eraser'. https://www.youtube.com/watch?v=HCeCVZqcpnE
But, there's some simple ways to tell that come along with basic building/construction knowledge/experience. If you don't know one closely, consider hiring a contractor or someone with building experience to do one walk thru with you. They likely can give a bunch of valuable reusable pointers for construction in your area.
Good advise. Most building codes require a fire wall/ceiling between units. Fire proof building materials can be drywall, concrete, of anything that don't burn. To test how noise travels between units in a multi unit building you could yell.nutspecial said:Simply guaging the standard area's building methods and wall thickness, combined with perhaps getting access to basement, attic, or even simply removing an electrical receptacle will tell alot.
IBScootn said:I bought the Seek thermal imaging camera for my iphone. It does show studs in walls if there is enough difference between the room temp and the temp of whats behind the wall; I didn't expect this and at first wondered what the pattern of lines were as I was checking quality of insulation job. Then it dawned on me - ceiling joists and studs. Doesnt work as well thru subflooring.
