colsaunders2
🔌 New-ish
- Joined
- Oct 2, 2019
- Messages
- 32
I picked up the T9 (36-pole version) in June and was having similar issues to those described above. Basically, a sufficiently-hard stop with regen (brake switch + throttle) would result in no Hwatts output. I had other issues that I was focused on fixing, so I used basic/cadence mode for a while. However, when my Baserunner died last month, I tried again with the "Infineon" controller (no dice) and then with the replacement Baserunner. Lo and behold, torque assist worked! 95% of the time, anyway. I've had a couple of instances where a sharp bump or carrying the kids trailer resulted in null output, but that's only been 2-3 times in 2 weeks (not every single ride, like before).
BR #2 - and this may be the key detail - does not have working speed passthru. My MAC (not GMAC) has regen but no internal speed sensor, so I'm running an external pickup. I also re-routed the CA3-WP and PAS cables below the downtube, perhaps keeping the gremlins away for the most post.
