The 6.5lb shengyi is looking appealing in my configuration. That's pretty high efficiency for a geared hub. And the power/weight ratio in a small wheel is fanstic.
I added a 5kph wind against me to try to account for the motorcycle tires and add 100 watts of load ( hopefully a pessimistic case )
Maybe this is a half decent answer to offset the added weight of the moto tire in the back.
Thermal characteristics of a small motor matter though, because i have 7% grades here and strong winds. Let's compare it to the MAC on the flat.
Both motors at 40mph on flat cruise:
MAC: 1731w - 1486w = 245 watts of heat to shed ( a lot )
Shengyi: 1712w - 1499w = 213 watts of heat to shed ( also a lot )
Going 40mph on both of these motors for extended periods of times is certainly out. But a couple miles are OK.
The fact that a 6.5lb motor can handle that for a period of time is astounding!
The MAC/GMAC, being a slightly bigger motor, is 1% more efficient on a 7% grade hill climb and these numbers get reversed. But climbing a mondo hill is rare.
I think the Shengyi is the better motor for what i want: 25-30mph cruising, a burst to 40mph here and there to avoid getting killed on fast roads with no bike lanes.
Maybe i need to pick one up and see what it's limits are. I'm thinking it's efficiency makes it a nice power surprise like the leafmotor was. This sounds like an OK powertrain plan for now.
