The first hours I was not totally happy, tight cornering at low speed was a bit weird - after the fork change to the 30mm travel fork - original one was non-suspenion, but I was already so spoiled... Will use a bigger rear tire (50-406 slick still fits) after this one wears down.
Below is a pic of the recumbent I'd like to try...M5 Low Racer:
Wonder how it would handle with a motor in the rear and a battery under the seat.
Recumbent lowracers are famously ill-handling because of the low center of mass height. Low CoM is great for trikes, but awful for bikes because it interferes with countersteering.
I have over 75K miles on recumbents, over 36 years, and the only broken bones I ever got were on my carbon fiber road bike. Turns out, riding head first on a step ladder is dangerous.
Few weeks ago ... adjusted the fork using a hydraulic press, replaced the rear shock with the ancient SID (has a separate feed valve for the negative chamber to get more sag for chain clearance without sacrificing performance) and fitted a narrower handlebar. Handling further improvedLet me know how that thing handles. I'm betting it's very agile, and a bit of a canyon carver.
Few weeks ago ... adjusted the fork using a hydraulic press, replaced the rear shock with the ancient SID (has a separate feed valve for the negative chamber to get more sag for chain clearance without sacrificing performance) and fitted a narrower handlebar. Handling further improved, feels great at any speed now.
Next thing to do would be a hinging mechanism for the seat, at the moment I have to take it of when I put the bike inside my car.
