Has anyone ever experimented with a torque sensor connected to the throttle pinout of a cheap aftermarket controller on a hub motor? Or does Anyone know if this could work?
I was thinking about Sempu T2 sensor (https://www.aliexpress.com/item/32967314504.html?gatewayAdapt=glo2nld) or similar.
Throttles produce an analog signal, usually something between 1 and 4 V and this type of torque sensor has an output between 1,5 and 3V. Speed set of aftermarket controllers is usually 1-4.2 V. The problem I see arise here is the desired minimum of 8 Volts input and, once connected, setting the right multiplier.
I don't need a throttle; I live in Belgium, and law forbids the use of a throttle. So I might as well try to connect a torque sensor to the pinout of the throttle.
This is ment to revive a Koga with ION rear hub motor. This motor will only run on its own Ion battery, which is not available anymore (and which was horribly expensive in the days it was still for sale). So I hacked the motor, removed the internal controller and led out the phase wires in order to run the motor on an external controller, this is supposed to work. (
). But I would also like to get the smootness of running on a torque sensor.
