I am doing a copper sandwich, 0.15 copper and 0.10 nickel steel. 3P configuration with 35mm copper between series connections. Based on the ampacity charts this will be 84A (5mm strips x 7)
The answer is nobody knows. I've done lots of research into this topic. If your referring to copper STRIP ampacity from the various tables online based on WIRE ampacity, than this should not be done. Always verify with temp gun.
Given dimensions of your strip, ambient temp, insulation, what cells your using, the welds and how many... There is no generic mathematical formula.
Tables online do not specify length of the strip which does play a role in ampacity. Nor do the tables online for copper wire specify ambient temperature or what insulation was used, or temperature of the strip...
Essentially we as humans have been making battery packs for a very long time, but still do not fully understand the physics enough to come up with a generic mathematical formula.
Something to invent and discover.
The closest thing we have is NEC 310, there's a table for bare copper wire in there in open air conditions (NOT in a battery pack) with ambient temp specified. However this is for WIRE and not STRIPS and should not be interchanged. So table is pretty much useless for building battery packs using copper strips.
