PublicToilet
Hi all,
I'm planning to build a new ebike shortly and I'd appreciate any feedback on the design.
I'm trying to make it reasonably stealthy/clean and I understand I'll have to sacrifice some speed and range for that. It's going to be used to commute around 25km return each day over slightly uphill terrain, and I'm mostly wanting the motor assistance for the trip there.
I've tried emailing Grin for advice but I haven't heard back from them yet.
The components are going onto a 2021 Marin Muirwoods, which has a CroMo frame with 29" wheels. The rear dropout width is 135mm and will need to be slightly widened to accommodate the 138mm motor, but I believe that should be fine from my research.
Motor: Bafang G310 Standard Wind
Battery: 36V 10.5Ah Bottle
Controller: V6 Baserunner Z9 Controller
Display: Mini OLED Display and Switch
PAS Sensor: 24 Pole PAS (HiGo Plug)
Harness: Main9 Superharness
Torque Arm: G311 Torque Arm or V5 Universal Eyelet Torque Arm
All components except the battery will be purchased from Ebikes.ca. The battery isn't ideal but suitable options are limited and that AliExpress seller seems to have reasonable reviews. I'll take the obvious precautions when charging it.
I'm unsure which torque arm will fit best on my bike, so I intend to purchase both and figure it out in person. I'm also not certain if the 12mm V5 torque arm is suitable with the 10mm axle on the G310.
I'm not planning to have a thumb throttle as this is unlawful with a motor above 200W in my jurisdiction and I'm risk averse.
Does anyone have any feedback on the above design?
Cheers,
PublicToilet
Cheers,
PublicToilet
