offGridDownUnder
🚴♂️ Mega poster
Like many other machines discussed here, I am using Li-ion batteries. I presume Li-Cobalt cells. The sort than can catch fire.
My current pack is from Cap Rouge in Australia, and uses name-brand cells (Samsung or Panasonic if memory serves) - the best possible approach as I understand it for these sorts of cells.
Lithium titanate appears to have the longest lifespan, but LiFePO4 seems to also have long lifespan, and is reputed to be fire/explosion safe. My ride is based on a Greenspeed Magnum Big Wheel, and has room for a larger, heavier battery. LiFePO4 appears to be about 2x weight and size of Li-Cobalt.
I'd like to hear comments on me using a battery like this:
48v LiFePO4
My current battery is 48v, 20Ah, and feeds to a Grin Baserunner and then a Grin V3 All-Axle motor. I also have a Phaserunner available to use instead.
It seems to me that the volts, amps (30 out rated), and total capacity meet my needs - what else comes into play? Can I use something like this? I have a Grin Satiator and also a programmable solar blanket for charging.
Any concerns, other issues to consider or find out values for? Is any of my information (or beliefs) mentioned above incorrect?
48v LiFePO4
