Eruss17
Hi
I’m new to e-bikes, but have 30 years of electronics experience in work.
I have acquired two Anolog Motion AMX Step e-bikes.
I have one functional battery (36v 7Ah).
Both bikes have the Topology SW102 controller and a bespoke controller/battery holder (Analog Motion Model LSW1188-34-3F, possibly a Lishui) I believe a Bafang rear hub motor labelled bbc36700a250w (250W 36V), but bike manufacturer says it is made by Aikema.
With a fully charged battery, battery ON (100% capacity in the 4 green LED’s), I press and hold the orange power button in the SW102, but it does not boot.
I have checked the connection to the SW102, and the wiring loom has 41v on the Power pin to the SW102 controller (on the JULET connector).
This is the same for both bikes. I guess it is possible for both controllers to be faulty or both displays, but I don’t know the history of either bike so now I’m stuck.
This bike doesn’t have a throttle, just a bottom bracket rotation sensor, which is plugged in.
I disconnected the 9 pin motor cable but no luck.
Is it possible to disassemble the SW102? Does the screen unclip of does it need to be gently heated for removal (like an iPad)?
Should the display boot with just power and no communication with the controller? If it does boot with power only, I would expect a communication error.
I attempted to disassemble the controller, but it appears that there are no connectors inside the controller housing, all wires are hard wired to the PCB.
Without a working display, I don’t know what is going on.
I understand that not all SW102 displays are the same (different communication protocols UART & CANBUS and potentially bespoke firmware) so how can I find a replacement controller. It doesn’t help that the manufacturer Anolog Motion, are not in business anymore.
Any advice appreciated
Regards
Russell
Regards
Russell
