heynow1010
New-ish here
I'm close to completing my upgrade of a ride1up FS with a motoberry controller plus a 60 volt battery, When I turn the key switch 60+v appears on the throttle display and hear the brushless motor spinning and accelerating when I press the thumb throttle. But the rear wheel does not spin. If I first give it a spin in the correct direction and then press the thumb throttle it just barely maintains the spin I initiially gave it manually. It's as though a centrifugal clutch is not activating. NOTE THIS IS WITH THE REAR WHEEL STILL OFF THE GROUND FOR THIS UPGRADE
Can you suggest what is happening please?
Any help is greatly appreciated.
Heynow
Heynow
