Hi. I flashed the latest version of the *.BIN file to my M820 powered by a 48V battery. Here are my observations:
I also have a quick question – after flashing the FW and calibrating, do I need to adjust anything else? Is there a micro-guide somewhere on what needs to be tweaked, if anything at all?
I'm really rooting for this project because it's a great motor and it deserves a good, customizable FW. Too bad it's so noisy :-D
- At a standstill (when not moving and not putting pressure on the pedals), the display constantly shows 44W in every assist mode.
- Canable alternatingly displays "MOTOR TEMPERATURE" as either 106 or 173 degrees Celsius. On the stock firmware, it correctly shows 30 degrees Celsius in the "CONTROLLER TEMPERATURE" field.
- Walk Assist, when pressed, starts at full power for a brief moment (no longer than 1 second).
- When I start pedaling, the motor sometimes acts as if it were disengaged; for about 0.5 seconds, it sounds like it revs up high without transferring any power to the chainring (even though that shouldn't be physically possible).
- Upon starting to pedal, the power is delivered abruptly (instead of smoothly/progressively). To be clear, it's not a massive surge, but roughly adequate to the pedal pressure – it's just the delivery that is too sudden.
- When I stop pedaling, the motor power is cut off instantly. A slight overrun would feel much more natural and pleasant.
