I suggest you do some research. Excluding all subsidies and other sources of cost bias, INCLUDING the cost of finance (build, legalities, land, connections) Solar energy is the *cheapest* source of new power generation right now. It's also becoming cheaper over time, something that's not true of many other sources of watts. That's the primary driver of the exploding use of solar (see graphs above), it's just cheaper. All its other advantages are secondary benefits, lack of emissions, ease of approval, public approval etc all make it a no-brainer but the real decisive shift towards solar is that it costs less than coal, gas, nuclear etc.
Regarding its 'paltry' output - are you kidding me? Are you incapable of understanding that small numbers can add up to big numbers?
It takes over 20 years to build new nuclear in the western world, primarily driven by risk averse approval bodies (understandable given the massively negative view on nuclear by the public). In the 15 odd years before you even begin construction in earnest on a nuclear plant you can build out a LOT of 150MW solar facilities, reaping the benefits of incremental efficiency enhancements and ever reducing costs throughout that period, producing a return the whole time.
Big, centralised generation is a dead end topology. It's not going to be relevant in a world where every home and many commercial buildings can become energy neutral and the amortized cost of doing so is LESS than the ongoing expense of purchasing power from conventional providers still seeking to reach break even on BILLIONS invested into legacy power plants. You're witnessing the start of a wave of energy disruption that will have wide reaching effects. Savvy business people will evaluate the business case of big centralised development, it won't stack up and they won't do it. You're already seeing this shift - you'll be seeing a lot more big projects get cancelled.
There is a LOT of land between cities, in areas undesirable for conventional development in almost every country. The area to power our world is not an issue, even at current power density. Even excluding the enormous tracts of unused land, just within urban environments is an enormous about of surface area ripe for harvest (and then nearby consumption)
The entire planet is solar powered - why not avoid the rube goldberg machine of birth, death, time and then combustion if you can just harness that original energy source in its raw form?
Regarding the age old objection, 'the sun doesn't shine at night hurr durr' - Elon Musk has proven that storage is economically feasible, ecologically sound and commercially viable *right now*. With further economies of scale and continuous improvement of the technology that's still in its infancy, efficient storage will go hand in hand with efficient collection. There's no need to transfer energy thousands of miles for consumption elsewhere - the sun shines everywhere. There's a happy middle ground between scale and complexity of deployment, but that middle ground sure as shit isn't producing power in an entirely different country and then stringing UHV transmission lines across the continent (or even ocean!).
Back on topic - the model 3 looks great for a car that packs a big interior in a relatively small envelope (by american standards anyway). I'm looking forward to taking delivery of my one some time next year.
I'm keen on the upgraded interior, all wheel drive, autonomous driving, supercharging and whatever the top shelf performance options work out to be. I'm expecting that's going to probably double the 'base' $35k.
