amberwolf said:as a couple of examples: i have an old 20ah a123 cell pack that can easily take 10a charge, doesn't even get warm. neither do my 20 and 40ah eig cell packs.
but a little 10ah 18650 pack gets warm at even a 4a charge rate, even with the pack opened up rather than in a case or in shrinkwrap. (it also gets hot, over 100f on the *outside* of the pack, under just a 2c (20a-ish) discharge rate (with short peaks up to 50a), when it is supposed to be a 50a continous discharge rate pack--but it does have a note in the original specs page saying not to do it). turns out the cells in it are actually only meant for 2c max discharge, so the pack was built and sold around a lie. (not surprising, and it happens quite a lot in the ebike battery industry). i don't seem to have the temperature data posted from the charging, just the discharging on the one test ride posted about.
https://endless-sphere.com/forums/viewtopic.php?f=14&t=81108
i used to have a lifepo4 18650 pack, and i recall heat as a problem in it, too, but i haven't had it for years (stolen) and no longer remember much about it, though there is a repair thread for it in my posts under vpower / cammycc or something like that.
SkipperDK said:That's very interesting. So I found the sellers recommendations for max charge which is stated at max 5A, is this overly precautious or what I should stick with?
that's probably even optimistic, and as john in cr said, i'd charge at a lower rate for everyday use. my guess is the seller probably recommends a 2a charge normally, and it probably comes with a 2a charger. most likely, the pack will last a lot longer at the original charging rate than a higher one. (without knowing what's in there, i wouldn't even make any bets it would survive a 10a charge once, much less everyday charging like that).SkipperDK said:So I found the sellers recommendations for max charge which is stated at max 5A, is this overly precautious or what I should stick with?
Thank you, I'll keep that in mind.John in CR said:If they say "max", then I'd go even lower for daily charging.
john61ct said:With even a top-shelf battery personally I stay below 0.4C for longevity.
When the cells are hot from ambient warming you can go faster without much "damage" (lost lifespan cycles).
When getting cooler than T-shirt weather, then need to go much slower
below 15°C my limit reco is maybe 0.2C
I'd start pre-warming below 10° if going over 0.1C
Now, I do coddle my cells, low C-rate discharge, low charge Vtermination, high LVC
If yours are being abused anyway, perhaps unavoidably in your use case, then maybe the reduced lifespan from "faster" charging will not be significantly greater anyway.
Too many variable to really quantify cause & effect.
amberwolf said:that's probably even optimistic, and as john in cr said, i'd charge at a lower rate for everyday use. my guess is the seller probably recommends a 2a charge normally, and it probably comes with a 2a charger. most likely, the pack will last a lot longer at the original charging rate than a higher one. (without knowing what's in there, i wouldn't even make any bets it would survive a 10a charge once, much less everyday charging like that).
but unless you know for sure what cells are actually in it (and remember the labels inside may be fake), and what the bms specs actually are, or you test to the point of potential damage or destruction, you can't really know what the pack is capable of.
keep in mind that many 18650 cells have pretty low charging rates, as little as 0.1c to 0.2c. a 15ah pack at 0.1c is 1.5a. at 0.2c is 3a. 5a is 0.34c. 10a is 0.67c. some cells can take that, and some can't. some can take much higher rates...but not most of them, and the cheaper the pack is, the cheaper the parts used in it usually are, which usually means low charge and discharge rates.
2A, mate.999zip999 said:What does your charger charge at now ?
Always sound.SkipperDK said:Well, sorry to say, I really do abuse my battery, it gets fully charged, and almost fully decharged at max rate. I need a bigger capacity and dicharge rated battery and it's on my wishlist.
I hear what all of you are saying. I'm thinking on getting a 5A charger only for when I need a fast recharge and then use the 2A charger as much as possible
john61ct said:Always sound.SkipperDK said:Well, sorry to say, I really do abuse my battery, it gets fully charged, and almost fully decharged at max rate. I need a bigger capacity and dicharge rated battery and it's on my wishlist.
You likely won't see any appreciable longevity effect then, as long as you don't fast charge in very cold temps
dogman dan said:Good plan. My current battery does not really state the max charge rate, but it seems to be at least 5 amps, based on the chargers the retailer sells with it. It might be able to handle more, but I seriously doubt its bms is good for 10 amps.
My charger is a satiator, which I can set to 7 amps max. I do use that setting, but only when I need a quick jolt, often enough not even to full. My normal charge rate is a 3 amps charge, used when not in a hurry, or not needing to just top it up a bit quicker. In a top up, the charger will not run at 7 amps anyway, since the flow slows down as the battery nears full. So if I store the battery at 56v, then I can run the 7 amps to fill it to 58v without it really ever getting to 7 amps flowing.
Neat thing about the satiator, it shows on its display what the actual flow rate is, which varies as the battery fills up. Slower at the end. While so pricy It took me years to get my satiator, its worth every penny I paid. Should have gotten one years ago.
the first thing is that it is designed and built to be able to be carried around or mounted on the bike or vehicle, so it can handle the banging around and vibration and weather, where it's a crapshoot with the cheap (or even expensive) typical chargers on the vibration/banging around, and pretty much none of them can be in wet weather.SkipperDK said:I've actually been thinking a lot about getting a satiator from grin. What makes it so much better and worth that much more money?
john61ct said:Worth is an opinion,
But
true charger with current limiting, also terminates when full, unlike a raw rectifier/PSU or DC converter
adjustable setpoint across a large V range, can be used with a variety of packs
adjustable current rate
Multiple units can be put in series or parallel
decent display
reliable, Grin is a well trusted North American vendor, support is available, warranty
Sent from my Nexus 6 using Tapatalk
amberwolf said:the first thing is that it is designed and built to be able to be carried around or mounted on the bike or vehicle, so it can handle the banging around and vibration and weather, where it's a crapshoot with the cheap (or even expensive) typical chargers on the vibration/banging around, and pretty much none of them can be in wet weather.SkipperDK said:I've actually been thinking a lot about getting a satiator from grin. What makes it so much better and worth that much more money?
because of the sealed design it's also fanless, so it's silent.
ends charge when current drops below a settable point, and disconnects it's output from the battery (whcih is very handy if you mount it on the bike and connected to the battery all the time).
if you have a thermal sensor in the battery, you can wire it to a threee-wire charge port so the satiator can monitor battery temperature, and can shutoff charge above a preset point.
you can setup multiple charge profiles, that can be setup for a main default one, and button select the others. so in a use case like yours, you don't need multiple chargers to have slow and fast charging rates, just the satiator.
it also tracks usage in each profile, so you can see how many wh / ah each one has charged up over time.
the profiles can be setup by hand on the charger itself via the menus, or via usb (with the adapter cable) from a computer.
that feature can also be used if you have multiple bikes or battery packs with different properties, but doesn't sound like it applies to your case.
it also has a warranty and actual customer service / help if you ever need it (though grin sometimes takes quite a while to respond via email, you can always call them), and spare parts are available for it if it does break. that includes firmware updates whenever improvements are made to the control software inside it (or the computer based setup software).
adapter cables exist for several common ebike charging port connectors.
the money you spend on it pays for development of other handy new ebike devices, and improvement of existing ones.
everybody doesn't need one. but if the features above sound like stuff you'd prefer over your existing setup, it might be for you.
