worldbicyclist
10 µW
- Joined
- May 22, 2015
- Messages
- 5
Hello guys,
I have considered doing a longer tour by ebike for several years now. I often do long bike tours, for example Europe to Southarica; Europe to Japan; Argentina to Canada, with non-touring bikes. I have used six different bikes so far, a rigid MTB-frankenstein bike, a hardtail MTB, a full-suspension MTB, a city-bike, a cyclocross hybrid and a carbon roadbike. For possible future tours I might try a folding bike, ebike or folding-ebike.
A redditor linked me to the video-logs of grindz145 and I found the 4400m journey to be very interesting and a good proof-of-concept that long ebike tours can be done. I'm reasonably fit and often bike light or ultralight, resulting in average distances of 100-150miles per day, I can only imagine that having an engine would increase the range even more.
I'm a bit sceptical when it comes to recharging, especially in third-world countries.
Unfortunately I have no background in electronics and have to read into the material first. I noticed a lot of conversion kits and DIY projects on this forum. I was more thinking along the lines of a bike like this: http://www.stromerbike.com/en/de/e-bikes/stromer-st2 Are these good values for an ebike?
If I do decide to go for an ebike, my route would most likely be Capetown to Addies Abbeba, through western Africa. It's about 8000miles, but I'm sure I can find a nice worthwhile detours. I'm very interested in your opinions, since I'm a veteran traveller, but have never used an ebike before.
A few questions, please excuse if they are insanely stupid:
1. Would a hub-dynamo up front hooked to your battery increase your range? Not trying to build a perpetuum mobile, but maybe it adds a few % to the milage?
2. How feasable is charging a battery with large-surface solar panels? I'm personally not the biggest fan of them, but I remember seeing pictures of touring-ebikers with solar panels on their trailers.
3. How much does weight/luggage affect the range? I usually carry 10-15kg of luggage, which is very little for a long bike tour. Does that help?
4. Best case scenario, ignoring the budget for now, what is the highest range on an ebike, going about 20mph per hour?
Thank you for your time and greetings from Taiwan,
Patrick from http://www.worldbicyclist.com
PS: Adding the necessary info now:
Desired max speed on level ground. mph or kph => ~20mph min.
Desired max range at what cruising speed. mph or kph => At least 200miles per day doing 20mph, hopefully per charge(?)
Preferred bike wheel size, or wheel size of bike you want to convert. Most common kits are for 26" wheels. => 28"
Brake type of motor wheel. Disc or not. => Disc or V-brake, I don't care.
Rider weight. => 188cm / 6"2'
Terrain. Exp: mostly flat, some short hills under 20% grade, I want to climb mountains, etc., etc. => Everything from flat paved roads to uphills/downhills on gravel, high humidity, heavy rains, high temperatures.
Budget. => No concern.
PPS: Approximate route http://i.imgur.com/dKrKG0R.jpg
